Need help picking a spark plug for my AFR 180 heads...
Anyone have any suggestions? I have AFR 180 heads (needing a gasketed plug). I have some form of discontinued iridium plugs in it now, and am in need of replacing them. Autolite 103's were suggested, but they are not a gasketed plug, and thats what I need. BTW, am running a D1SC at 15-16#'s of boost on my 383 in my sig.
I am wanting to stick with an Autolite plug here. I've got it narrowed down to either an Autolite 3922, or a 3923, but I'm not sure which one is the same heat range as an Autolite 103.
Does anyone know? Or know which I should run based on the approximate boost level (15#'s or so) I am at??
Guys, I can't run the 103 because I need a gasketed plug for my AFR heads. The 103 is the ideal heat range, but I need to go with either the Autolite 3922, or the 3923.
Between these two plugs, which should I run?
BTW, I don't want to run NGK's.
The 3922s are colder than the 3923s. Try the colder plug and see how it does. If it fouls, go one step warmer. However, from what I've seen, you want the NGKs...same price as regular plugs...R5671A-8 even colder, prolly not req'd. R5671A-7 cold. These are flat seat plugs and are properly designed to disperse and dissipate heat in high performance engines.
Just checked. The 71's are non-projected. The 72's are projected nose. Otherwise, they're the same plug.
A good thread http://web.camaross.com/forums/showthread.php?t=431689
We run NGKs 7 heatrange
Darth_tsunami
V6 Tech
09-18-2015 01:57 AM
