New motor smokes... alot...
Old 07-28-2003 | 10:04 PM
  #46
Brandy's Avatar
Originally posted by SMOKNZ
I'm starting to think the TT kit is only good for 550 RWHP or so. It takes alot of boost to get it to that level though, too much. I'm definately looking for something else to get that power level with alot less than 18 psi from my setup.
Bill
I'll find out for certain. My car made 571rw uncorrected but it was spinning the tires past 104mph (5,100rpm) with anything over 10psi of boost. You can see the graph for yourself here . I really think it would have hit 650 or so if the tires stuck, I was on 275/50/15 drag radials btw. The engine on the bottle had it's power peak at 6,100rpm before. It sure felt a helluva alot faster than the mid 10's it ran with the nitrous
Old 07-28-2003 | 10:11 PM
  #47
Brandy's Avatar
Note: If I remember correctly we tried 14psi with a little more power as a result. We were running out of time though so we got stupid and tried 20-21psi and went BOOM!.
Old 07-29-2003 | 06:31 AM
  #48
Jesse_Boyer's Avatar
550-600 is most likely the max of the TTi kit as was said above. Personally, I'd like to use most of the TTi kit, max it out, and THEN build some slightly better parts and see what improves. Moving the wastegate so it will control all the exhaust and not just one bank is just one is a thing I'll change.
Old 07-29-2003 | 03:30 PM
  #49
SMOKNZ's Avatar
I still use the stock crossover thats only 2 1/4 inches. I plan on putting a flexible peice of braided stainless exhaust in the crossover so the flanges will seal better. I looked into moving the wastegate, but i really don't have the room unless I route the wastegate vent on top of the log, and that wouldn't really look all that great. I run the ATI twin intercoolers and the area in front of the turbo is packed.
Bill
10-31-2016 11:09 AM
alex5366
03-27-2015 03:30 PM
transam_388
03-15-2015 11:53 AM
NewsBot
12-28-2014 06:20 PM
Quick Reply: New motor smokes... alot...
