New results. questions on gearing and my mph
Old 11-07-2007 | 12:51 AM
Blownbird355's Avatar
New results in sig ran 11.35 @ 121.xx mph with 4.10 gears through 4l60e going through traps at 7k I bought the 12 bolt used with 4.10's but will go 3.73 and prob a little taller tire to get revs down. My question is does my et seem to match my mph?
Old 11-07-2007 | 06:00 AM
97s10ondubs's Avatar
Yea it's not way off or anything, get those tires though and you might pick up some MPH because you are out of the powerband at 7k unless you have a huuuuge cam. Should probably bring your et down a little also. I never got a chance to get bigger tires and run on spray before I put a hole in one of the pistons, probably would have gone low 10's.
Old 11-07-2007 | 06:38 AM
RBE17's Avatar
I'd get the tires first and see where that puts you.
Old 11-07-2007 | 09:43 PM
CANTONRACER's Avatar
The taller tire will not hurt you....and as mentioned, then go from there.
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
jb4xx
02-02-2015 10:00 PM
Alex Barnes
01-24-2015 10:21 PM
Quick Reply: New results. questions on gearing and my mph
