O2 sensor mounting location
Old 05-22-2006 | 11:33 AM
davepl's Avatar
Due to clearance issues, I had to move my O2 sensors back about 12" from the header collector.
I know they like it more forward if possible, but they seem to do ok way back at the tailpipe when you're on the dyno.
So is the preferred forward mounting an emissions thing (getting the sensor to warm up sooner to go into closed loop) or is it a lag issue (since it takes a few microseconds longer to move 12", maybe the ECU can't react as fast)?
Either way, will 12" make a difference?
Old 05-22-2006 | 11:36 AM
Sparkz28ss's Avatar
Re: O2 sensor mounting location
I doubt it..
I just dont like to have mine after the collector ...
just so if I have a leak my car wont run like assbag
Old 05-22-2006 | 11:37 AM
davepl's Avatar
How is assbaggishness prevented by being in the collector? Isn't a leak a leak?
Old 05-22-2006 | 12:07 PM
davepl's Avatar
Never mind, I get it now... a collector leak, which is common, won't necessarily affect the sensor if the sensor is upstream of the collector, but if its downstream, it will for sure.
Old 05-22-2006 | 02:19 PM
Sparkz28ss's Avatar
exactly ......
HectorM52
07-30-2017 11:46 AM
Chet1185
Parts Wanted
03-15-2015 04:29 PM
Jazsun
12-29-2014 12:14 PM
Timberwolf
07-20-2002 08:45 AM
Quick Reply: O2 sensor mounting location
