p600b or p1-sc
FYI the P-1SC is as follows:
Pros:
Stronger
Cooler running
Easier to install (no oil lines)
Upgradeable to a D-1SC
Cons:
slightly more expensive
Requires oil changes every 6000mi
You decide:
It is Quieter.....
Hope this helps.
Pros:
Stronger
Cooler running
Cons:
You decide:
It is Quieter.....
Hope this helps.
The biggest problem with the P1SC is leaky seals. Every P1SC that I have seen has leaked. ATI will not cover this under warranty. I believe last time I checked it cost $250.00 to replace the seals.
IDOXLR8 why do they leak and where? i am buying a used p-1sc w/low miles and i want to make sure it doesn't need the seals changed. also you seem to be very up on prochargers and your setup sounds nasty, generally how long do compresers last?
Matt
Matt
Matt
Matt
Take it for what it's worth but as far as smaller blowers I think Vortech S-trim is a better blower than an ATI P1SC.
I don't get it it seems like everyone here runs an ATI but no one ever says anything good about em.
I run an ATI a P1SC and like it. I have put almost 50K miles on mine. It works great. It does leak though, mine has been leaking since after the first week that i put it on there but has not cause me any problems other than it being a little oily. I had a few folks that owned or knew someone that owned a P600B and they all told me that My P1SC is a lot quieter. Plus the P1SC can be upgraded for about ~1100 bucks later to D1SC specs when more boost/power is needed.
PS....Lonnie Pavtis is the guy to go to when you want an ATI Procharger. His Customer Service, Tech Support is UNMATCHED in the industry and I am sure many others on this board will tell you the same.
Thx,
Claude
The P600 is old tech, and the D1 is more than most need. The P1 is perfect for most people. It has enough to get you into the 9's with the right motor. Most people aren't even close to 10's with the D1- so whats that tell you.
Means they spent too much on the wrong parts. Get a used P1 and use the rest of your money to get some heads.
