People making 550rwhp or more...
#16
Originally posted by stealth2
Race cars and tight budgets are incompatible. Our experience has been to double whatever budget you have created and it might be close.
#17
just get the Street Twin, you will regret it later if you dont. also the centerforce DF for the LT1s is junk. i have been through about 5 or 6 different clutch combos on these cars, and on my last 3 6 speed combos have gone with a street twin as well as using them in local cars i work on. only down side to it besides the price is that the ST is real hard on drivetrain and suspension parts if yours arent up to the task.
IMO the 48lb injectors will be a little on the small side unless you are planning on a superfueler or other means of adding additional fuel. i currently have 42lb injectors with a maxxed out superfueler (3-24lb injectors) and the 42s are running 28+ms pulsewidths so its time to step up. i wouldnt run higher fuel pressure to make the injectors act bigger since that will reduce the performance of your fuel pump which is already on the small side (pumps flow less volume at higher pressures)
#19
#20
Since your prepping the block, go ahead and have it receiver grooved or o-ring'd, and drilled and tapped for longer and bigger (9/16) heads studs.
#23
Originally posted by RealQuick
The guy at combination motorsports said if i am only run 12-15psi, then the o-rings werent necessary. I believe he said if I were to run 20+psi it might be a good idea...
Since your prepping the block, go ahead and have it receiver grooved or o-ring'd, and drilled and tapped for longer and bigger (9/16) heads studs[/B]
#24
Originally posted by blk95zm6
I just hope you have bettor luck with th S\C'r than i apparently did jon.....900 miles and half my boost is in the crankcase...
#25
Originally posted by sleeperz28
Hell I run 25psi and O rings arent necessary.
This block will not need it. There are a handful of guys making the power that I'm and I none of us did this. I know two personaly, for that matter.
10-31-2016 11:09 AM
NewsBot
01-08-2015 11:29 PM
NewsBot
12-21-2014 06:55 PM
