people using Turbo Tech kit and headers.
Old 07-16-2003 | 01:13 AM
Dave19yz28's Avatar
I'm going to be getting the turbo technologies LT1 turbo kit....once i finish saivng up for it. I was just curious if anyone here knew if the kit would work with aftermarket headers. I know long tubes and midlenths are out...but Shorty would work wouldnt they, i mean, ones that bolt onto the factory y-pipe?
Old 07-16-2003 | 01:22 AM
GhostZ's Avatar
Won't work.
I really haven't looked at the turbo tech kit but I haven't heard many good things about it. You might want to check out the PTK kit:
http://www.proturbokits.com/gmkits.htm
Old 07-16-2003 | 01:40 AM
Dave19yz28's Avatar
any other opinions on the turbo tech kit?
Old 07-16-2003 | 02:12 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
im with ghost. steer clear of the turbotech. check out proturbo
Old 07-16-2003 | 02:16 AM
White_94_TA's Avatar
Agreed. If you're going turbo.. Go Proturbokits.
Old 07-16-2003 | 09:11 AM
EddieP's Avatar
Originally posted by GhostZ
Won't work.
WRONG! Any passanger side header that bolts to an unmodified dual cat y-pipe will work with the turbo tech kit... SLP, early JBA design, ect. I've seen some decent power from the turbotech kit, but in every case all most all the components were replaced with better parts or modified. The TT header isn't a great design, though...
Old 07-16-2003 | 10:42 AM
sleeperz28's Avatar
Actually the early JBA will not bolt up to the y-pipe. I bought one for a 94-95 didnt work, so i returned it and made my own pipe.
As for the kit its junk! I had it big problems with the manifold leaking for the first year. Got that fixed and a few other things to realize I could not get any more then 11psi out of the kit. It had too much back pressure and i would not squeze a bigger housing to correct it. Sold it made a twin turbo kit and now I have never been happier
Old 07-16-2003 | 11:57 AM
EddieP's Avatar
It most certainly will work, but it must be the early DUAL CAT (96-97) JBA passanger side (no way a 94-95 setup would work on the TT kit). Not sure when they started doing this, but JBA began selling the 94-95 passanger side header with their dual cat headers, which required 96-97 users to cut about a foot off their dual cat y-pipe and weld on a ball flange.
Old 07-16-2003 | 02:04 PM
Dave19yz28's Avatar
Right, i kinda figured it would work...i mean, so long as it bolts up to the factory y-pipe. The only reason im thinking about staying with turbo tech is that 1 its a little cheaper, and two, when i put the kit on i am only going to run 5-6 pounds AT MOST...as i will have the stock, until i have enough for a forged 355, or 383.
Any other opinions?
Old 07-16-2003 | 02:17 PM
Tiago's Avatar
everyone says this until they get a taste of the boost, then hp greed takes over.
Old 07-16-2003 | 02:45 PM
got_hp?'s Avatar
its not much cheaper............and you will kick yourself in the head down the road for not getting the proturbokit instead.............turbotech has a bad track record.
Old 07-16-2003 | 03:19 PM
Dave19yz28's Avatar
Haha...i know, my friend has a turbo supra...yay boost! Thanks for allthe replies guys...so ill definately stay away from turbo technologies...is there anyhting out there better then the pr turbo kits? Also, obviously with a larger pump/injectors but, what HP can the stock fuel rails hold? Just for future reference
Old 07-16-2003 | 03:40 PM
EddieP's Avatar
Stock fuel rails are good for some pretty serious power... A few of my friends of mine made 680rwhp and 645 rwhp (blower cars, too!) with the stock rails AND stock lines.
Old 07-16-2003 | 03:50 PM
96TurboTA's Avatar
I've got a used TT kit right now. The only reason I bought it was because it was real cheap. I wouldn't buy one new. The fit and finish is terrible. I had to have the log manifold planed, and fabricate an S pipe to the existing cat. The intercooler blocks most of the radiator too. I'm most likely gonna buy a PT kit or build my own over the winter.
Old 07-16-2003 | 05:31 PM
SMOKNZ's Avatar
I have one of those modified TT kits, and will be replacing it this winter. I have not got the thing to seal up (exhaust wise) since day one. All said and done I could have probably bought a Pro Turbo Kit twice over with all the work I have done to this kit. My friend bought the intake piping for his car and front mounted the Intercooler. He also will will be redoing his log style header this winter. BTW aftermarket headers do work as long as they are Dual cat one's (96-97) I run an SLP header. Made Hp/Tq in sig with stock rails and lines and regulator at 18 PSI boost.
Bill
Quick Reply: people using Turbo Tech kit and headers.
