procharger help?
Old 03-06-2004 | 06:51 PM
94Z286SPEED's Avatar
procharger help?
i just got a used kit where do you get the oil pressure line mounted to? the block somewhere? but where?
....and why is the return line so much bigger then the feed line?
oh this is for a P600B thanks Brad
Old 03-06-2004 | 07:38 PM
BruceVette's Avatar
you have to punch a hole in the oil pan and tap it. Run a T ot fitting there.
Old 03-06-2004 | 07:41 PM
the punched hole in the pan if for the return line, where does the pressure side come from?
Old 03-06-2004 | 09:37 PM
97WS6SCharged's Avatar
On an LT1, there's a pressurized oil port just above the oil filter that is plugged up from the factory. Just unplug that and hook your oil feed line into it. Oh, on some 94's the oil pressure sending unit may be plugged into that port.
Oh, the oil return line is alot bigger cause the oil must gravity drain back into the pan, unlike the feed line which is under pressure at all times.
Check out page 9 of this manual, it's not ATI, but it's the same principle.
http://www.vortechsuperchargers.com/...s/4gh218im.pdf
AviatorDave
12-19-2016 06:35 PM
D1SC383LT4
01-01-2016 01:56 PM
95blkss
09-22-2015 03:18 PM
95blkss
07-13-2015 01:28 PM
jdelaprida
07-04-2015 03:02 AM
Quick Reply: procharger help?
