Procharger oil (there is got to be something else i can use )
Old 03-21-2011 | 08:55 AM
siguy's Avatar
I don't like mail ordering every time i need oil and paying their Hi prices for their mystery oil.. I use my car allot and like to change it every 2000-2500 miles. (with my regular oil changes).
So I am looking for something off-the-shelf.
I find it hard to believe procharger makes it's own oil and there got to be anther oil i can use...
Imo i still think the oil it to thin ... i have yet to see a procharger without oil in the intake...
please as I see form other posts (to use their oil only!!!) I find that as crap and most don't know what there are talking about or don't even own a procharger and only go by what they read from procahrger...(of course they don't want you finding out that there oil is like someone elses) yes they make a great head unit but most of there other stuff is overpriced (just like their tensioners (which are junk) belts and that stupid orange hose they used for the lt1's (again this is my own opinion ).
need some good advice on oil and if you state just to use the procharger oil please explain why and what makes their oil so golden (i have yet found a technical explanation on that fact).
Thank you
Old 03-22-2011 | 04:26 AM
97WS6SCharged's Avatar
Re: Procharger oil (there is got to be something else i can use )
I'd almost be willing to bet they're just using a motorcycle type oil with anti-frothing additives in their blowers. I freely admit I don't have a Procharger (Vortech guy). If you really wanted to be sure you could always have their oil analyzed to see just what's in it.
BTW, ATI is no different from other companies out there. The stupid oil feed fitting that my Vortech uses is only made by Vortech and costs $55. They all bend you over when you need something and generally charge you extra for lube (or oil).
Old 03-22-2011 | 07:46 AM
onefastmx5's Avatar
No clue what oil ATI uses in their self contained units, but 97ws6 is on the same idea that i'm on. Motorcycle oil is formulated to lubricate gears (transmission), wet clutches, withstand HIGH rpm... so I happened to switch completely over to standard 10w-30 motorcycle oil in my car when i installed the oil fed blower.
Old 03-22-2011 | 11:55 AM
siguy's Avatar
Good point about motorcycle oil but i am looking for more depth because i use the car allot and like to change the oil often
Old 03-22-2011 | 08:16 PM
onefastmx5's Avatar
well i change oil every 500-1000 mi, and i've been using motorcycle oil for about 10k miles now.
Old 03-23-2011 | 03:50 PM
siguy's Avatar
yes but i think your set up uses the engine oil mine is a self contain unit with only about 6oz of oil in it..
94Form
07-17-2015 10:56 PM
Noct
07-14-2015 01:18 AM
jl1ne
07-07-2015 08:38 PM
streetbad
Advanced Tech
07-05-2015 10:40 PM
SergheiS
07-05-2015 03:27 AM
Quick Reply: Procharger oil (there is got to be something else i can use )
