running a MAF under pressure
Old 07-22-2005 | 12:53 PM
guardrail's Avatar
I did a search, nobody really touched on this. Does anything need to be done with the maf to make it work properly under pressure as apposed to the suction side of a s/c?
Mine has no screen or anything, any downsides to running it on the pressure side?
Old 07-22-2005 | 12:57 PM
97RedT/AWS-6's Avatar
Re: running a MAF under pressure
No, X amount of air passing from entry to exit is the same on both sides of the supercharger.
Old 07-22-2005 | 01:04 PM
guardrail's Avatar
well my recirc is closed loop no and I'd like to open it up for cooler charge. Also I sort of meant, will it hurt the MAF to be under pressure?
Old 07-22-2005 | 01:30 PM
I've never heard of it being a problem, and a lot of people do it. If someone has had a problem, hopefully they will respond.
Old 07-22-2005 | 01:39 PM
Teufel Hunden's Avatar
No, you won't have any problems running your MAF as a blow through, unless the MAF itself was flawed to begin with.
Old 07-22-2005 | 01:41 PM
94 NO TOP Z's Avatar
I've been running mine for 3 yrs that way with no problems.
Old 07-22-2005 | 01:43 PM
guardrail's Avatar
this is the type of stuff I wanted to hear...sweet
DirtyDaveW
12-01-2016 05:37 PM
pete53
12-09-2014 07:31 AM
formula218
12-02-2014 04:27 PM
nophix
11-30-2014 10:26 PM
07-04-2005 05:00 PM
Quick Reply: running a MAF under pressure
