Short Block For ~700RWHP?
Old 01-15-2009 | 07:14 PM
  #31
engineermike's Avatar
Originally Posted by boosted-lt1
... Stiffer bores are going to make more power as there is less deflection under load and better cylinder sealing. D. Vizard seems to think as well ...
We dyno'd a ~640 hp NA SBC with an OEM 400 block, then a Dart Little M. It gained about 6 hp, but 30+ ft-lb torque.
Mike
Old 01-15-2009 | 07:30 PM
  #32
boosted-lt1's Avatar
Would a street fill benifit the main area to any significance? 2-bolt, 4-bolt straight, 4-bolt splayed?
Thanks,
Old 01-15-2009 | 07:31 PM
  #33
Thanks,
The problem with the mains is cap-walk. No amount of filling will stop that.
Old 01-15-2009 | 07:39 PM
  #34
Mike,
I'm kinda having a hard time visualizing mains walking. With 2-bolt studs I'm assuming you've got the clamp load. Splayed mains tie you into block better. What about straight 4-bolt?
Are we talking twisting in the crank?
Thanks!
Scott.
Old 01-15-2009 | 08:00 PM
  #35
Mike,
Thanks!
Scott.
No, not twisting the crank. The main caps slide (on a microscopic level) around on the block. This causes fretting damage at the interface. It means the main bolts aren't doing a good job of making the main cap stay still. 4 bolts means double the clamping force, roughly. I'm not convinced that splayed mains help with this since there is already a register-fit to prevent horizontal motion, but I am seeing some fretting damage with my 4 bolt straight steel caps.
There are pictures of fretting damage on turbomustangs.com. Do a search for "grenade", a 2-bolt main stock bottom-end 700 rwhp freak.
Old 01-15-2009 | 08:38 PM
  #36
Haven't checked the link yet, but thanks. So there are lateral loads (cross-car) causing the mains to walk. I can see how a 4-bolt straight main helps in this regard.....more friction.
Now 'splayed' with outer bolts angled outward...You've got the cross-car component partially taken by the tensile load of the outward angled fasteners.
Am I close?
-Scott.
Old 01-16-2009 | 06:44 PM
  #37
Scott, the main cap has a register fit that prevents side-to-side motion. I've heard of pinning the mains to prevent axial motion also. I believe this would be more affective than splaying the outer bolts.
Old 01-17-2009 | 09:36 PM
  #38
T/A KID's Avatar
Mike I have heard you talking about that 700rwhp mustang before with 2 bolt mains. How many Rpm's is he turning?
Old 01-17-2009 | 09:38 PM
  #39
It's a TPI 350. I don't know for sure, but with the stock TPI runners, stock cam, and stock T3 S60 turbo's, my bet is very low rpm.
Old 01-19-2009 | 11:12 AM
  #40
Ponyhntr's Avatar
Here's the ultimate LT1 block...
http://cgi.ebay.com/ebaymotors/GENER...1%7C240%3A1318
One of 10!
Old 01-19-2009 | 12:51 PM
  #41
1996camaroSSclone's Avatar
Damn!!! I would love to have that engine block. Thats worth more than the entire car that you would put it in.
Old 01-19-2009 | 06:28 PM
  #42
I'd like to learn more about using dowel pins in the stock mains as Mike suggests. Does anyone know somebody with experience with this?
Thanks,
Scott.
Old 01-19-2009 | 06:42 PM
  #43
Thanks,
Scott.
I got that from a local engine builder, but a google search turned up that World blocks are doweled, as are LSx blocks and some old Pontiac blocks.
MadMav
06-08-2015 11:38 PM
R@mpage
04-20-2015 10:02 AM
pimpss96
02-12-2015 01:28 PM
ch3vyb1gbl0ck
01-28-2015 04:45 PM
11racing
Classic Engine Tech
12-26-2014 05:40 PM
Quick Reply: Short Block For ~700RWHP?
