should i switch my ai blower cam???
Old 08-07-2012 | 09:06 PM
  #16
95maroboi's Avatar
Re: should i switch my ai blower cam???
im not sure what the timing chart looks like**
Old 08-08-2012 | 03:54 PM
  #17
BIGCATPOWER's Avatar
you need to find out. anything you do with out knowing what the timing is set at will be a waste of time and effort.
Old 08-11-2012 | 07:15 PM
  #18
95maroboi's Avatar
i got recommended a 224/232 555/565 114 or on a 115 lsa.do you think it would be worth the swap to make it more boost friendly?
Old 03-17-2013 | 02:38 PM
  #19
streetbad's Avatar
Get a new torque converter.
Old 03-19-2013 | 11:53 AM
  #20
Purple Poncho's Avatar
Im not to happy with the power and low end torque of my car and i think it has alot to do with the cam.Im getting new heads and i think i can gain alot more power on a different sized cam.The specs on my old motor is..
355 lt1
8:9:1 compression
ai 200cc heads
ai custom blower cam 219.5/229.5 .555 .555 111.5 lsa
ai intake manifold
58mm monoblade
vortech si blower at 12 psi
That custom cam looks a lot like the old school CC305.
220-230, .544-.544 lift on either a 112 or 114.
Old 03-19-2013 | 03:27 PM
  #21
95maroboi's Avatar
its very similar to the cc305 cam but thats what advanced induction cusom grinded for my set up.
I have a new build in the process that will be
383
afr elimantor heads hand ported 300/240 cfm
vortech v7 ys blower 12-15 psi
custom high lift blower cam 223/235 .610/.629 114 LSA
Old 03-20-2013 | 06:47 PM
  #22
Clary's Avatar
Try running your set up on the dyno with the blower intake unhooked from the blower,the intakes on the lt1 are so restricted.Mine went from 560 rwhp to650 rwhp unhooked.
10-31-2016 11:09 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
95maroboi
06-07-2015 12:18 PM
MadMav
05-25-2015 09:35 PM
Quick Reply: should i switch my ai blower cam???
