Single turbo guys, what are you doing for O2s?
Old 05-11-2004 | 06:00 PM
Chrisbequick's Avatar
I know I shouldn't put them into the exhaust before the turbo, so the only thing I can think that will work is to put them both in the downpipe. It may sound silly but I hate to have the extra restriction of the 2nd O2 sensor in the DP if I can use just one. Can I splice them together and keep them functional, do I have to mount them both in the DP, or is there another alternative I'm missing?
-Chris
Old 05-11-2004 | 06:10 PM
92LT1RS's Avatar
Is the snout of an O2 sensor really that much of a restriction though?
Old 05-11-2004 | 07:00 PM
96TurboTA's Avatar
I'm running my passenger side pre-turbo, and driver's side post-turbo. They don't seem to be affected at low boost levels(7lbs). AFR is fine.
Old 05-11-2004 | 10:48 PM
got_hp?'s Avatar
i was told pre-turbo O2 is a big no-no.
Old 05-11-2004 | 11:21 PM
EddieP's Avatar
The O2 sensor came "pre-turbo" from the factory on Grand Nationals and T-Types ... Aftermarket race headers for the turbo buicks also locate the o2 before the turbo - my guess is that if there were a problem locating the o2 before the turbo, the TR guys would have found out by now.
Old 05-12-2004 | 09:08 AM
JZ 97 SS 1500's Avatar
Their is no problem running them pre-turbo or post turbo. I run them on my GN pre turbo, and on my SS post turbo, as well as my Supra post turbo. The sensor doesn't know where its at in the exhaust...hehe
Jose
Old 05-12-2004 | 11:50 PM
97WS6SCharged's Avatar
The same exhaust that comes out of the cylinder heads is the same exhaust that the O2s will read before or after the turbo. It may be a few degrees cooler, but your O2s should be heated so not a problem. I'd go ahead and stick two of them in the DP for ease of tuning and so you don't trip a SES light or anything.
Highlander
01-12-2020 02:13 PM
DirtyDaveW
03-15-2015 07:01 PM
Red97LT1
08-07-2002 05:45 PM
LT1runner
33
07-24-2002 01:19 PM
Quick Reply: Single turbo guys, what are you doing for O2s?
