Single turbo ls1
Old 06-24-2004 | 08:55 PM
jm8881's Avatar
Single turbo ls1
Just recently I got this crazy idea that a turbo would be fun. I've been looking in this forum for about 30 minutes and my search has turned up all kinds of stuff for the lt1 but what about us ls1 guys? I did find out that you want to keep the boost low since the bottom end isn't really capable of higher boost numbers. And an entire premade kit is just a lil expensive for me.
I was thinking like 6 psi would be just enough boost to have that fun I was thinking about in my crazy idea. I've seen the Honda guys scrounge up parts and have a complete turbo system for well under $1k. Is it possible for us to do the same? I'm guessing a turbo, new injectors, piping, turbo header, and a custom pcm tuning would be required. Has anyone done this cheaply?
Old 06-24-2004 | 09:57 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
There are some LS1 turbo systems out there.
LS1 motorsports had a single turbo setup, and I believe Stainless works is now retailing it.
Turbo Technology recently came out with a 'race' single turbo setup. Mightymouse has been having good results with it.
To answer your question though, you will not "properly" turbocharge your LS1 car cheaply.
Unless you can do all the fabrication yourself, you will need to buy a system. And, FWIW, the cost of the actual turbocharger should be the least of your worries.
The most inexpensive route would be the rear mount STS turbo. (turbo placement is where your muffler is now). It will have some limitations in regards to maximum power and response, but should work well for modest power gains.
And as with any forced induction system, you will then need to address the fuel system/tuning/driveline.
Old 06-24-2004 | 10:01 PM
jm8881's Avatar
That sounds really, well, weird. I'll check it out though. Thanks.
Old 06-28-2004 | 09:52 AM
Ws6cott's Avatar
my shop does tons of turbo work in the detroit area and ill be the second one to tell you that turbo lS1's arent cheap. mines almost finished and i ended up way over what i planned to spend and the cars been down for close to a year.
some of the kits on the market seem to be priced well when compared to custom set ups.
heres an example of what can be done if you fab your own
http://www.ws6cottformula.cz28.com/i...dfront_003.jpg
ducttape1975
Classic Engine Tech
03-26-2016 04:17 PM
ducttape1975
07-10-2015 06:29 PM
mrwz28
07-08-2015 09:11 PM
NewsBot
07-08-2015 06:47 PM
camaro02DK
07-05-2015 09:04 AM
Quick Reply: Single turbo ls1
