Spark plugs
Old 07-16-2007 | 03:16 PM
93BlackTA's Avatar
Spark plugs
Ok, first off, i spent most of the day using the search function and came up with some useful info on spark plugs.. I have AFR heads so i need a gasketed spark plug. I have a Procharger with 12lbs of boost. The trouble i am having seems to be the spark blowing out at higher RPM's and acting like a rev limiter. I currently have TR6 plugs gapped at .035" but i need to replace these with a gasket type plug. Should i get a non-projected tip or projected tip? What should i close the gap to?
Old 07-16-2007 | 10:32 PM
sc68z28's Avatar
Not sure if this will help, I'm using a Champion C57YC, stock#791, gap .028 to .030 max. With 1st gen Dart Pro1 heads, @16 lbs boost.
The C57YC is a pretty cold, 3/4" reach, gasketed plug. I'm not sure if it is projected tip??
It's the plug a dyno guy told me to run. Works well in my deal.
---Bill.
Old 07-16-2007 | 11:05 PM
roguedriver's Avatar
You'll want to run a non-projected tip plug. I ran projected tips at first but ran into the same problem. Going to a non-projected took care of it. You should be good with 2 heat ranges colder then stock. I tried 3 ranges colder using the Autolite racing plugs which are non-projected with a cut back ground strap, but they were starting to foul during cruise driving.
Ken
Old 07-19-2007 | 05:14 PM
AutoRoc's Avatar
-7 NGK non-projected tip gapped around .030" sounds good to anyone? Definately start by closing the gap, it can do wonders. Stronger spark would be the next step after that. I was running FR5's projected tip and they are great on motor and cruise but a 150 shot made them look a littrle too hot so I went to the non projected -7's. These look great and should be good for more juice too. Yes both of these are 3/4" gasketed for your style head.
Old 07-19-2007 | 05:40 PM
CALL911's Avatar
I am using an Autolite 3922 plug in my AFR 180 heads with my D1SC at 14.5#'s of boost with a .028 gap, it seems to be the perfect combo for my car.
Last year when I initially had my car tuned I was running a bigger gap and above 6300 RPM's I was seeing similar effects of the boost blowing out the spark.
I reccomend staying away from NGK plugs as my tuner as well as other tuners and other members on here have had issues with running them on their FI applications.
jwade88
06-14-2015 09:38 PM
jayblev95
06-07-2015 04:04 PM
blkWidow
05-03-2015 08:42 AM
nikko
04-20-2015 07:56 AM
94Z28LS1toLT1
02-28-2015 08:33 PM
Quick Reply: Spark plugs
