Teaser vid of my turbo setup...
http://media.putfile.com/new-setup
Real quick's hot parts + ball bearing turbonetics T76 = very quick spool
More details on the setup here...
http://web.camaross.com/forums/showthread.php?t=545467
For the lazy people out there that dont want to check the links to other threads, here is his setup:
355 9.5:1 compression
stock crank
eagle rods
wiseco pistons
splayed mains
all arp hardware
1074 head gaskets
STOCK intake
STOCK TB
STOCK cam
1.6 rr's
lt4 valve springs
Th400 with a coan 4000 nitrous converter(tight)
Hybrid 8.8 3.55 gears 33 spline axles spool
26x11.50x15 et streets(going back to my 325/50/15 mt dr's soon)
Real quick's log manifold setup
http://web.camaross.com/forums/showthread.php?t=541874
Turbonetics ball bearing T-76 with a .81 ar
30x12x3 FMIC
3" charge pipe
silicone cuplers w/ all tbolt clamps
3" downpipe connected to a 3" cutout to a stock catback
44mm tial WG
RFL wastegate
Prosport boost guage
Joe P MBC
lc1 wideband w/ XD-1 guage
42lb injectors(60's will go in as soon as I need them)
255 intake pump with a kenne bell boost a pump
obdI conversion tuned by me w/ tunercats(hopefully will soon be going megasquirt)
No p/s, no hvac, no abs, no front bumper support, no sway bar
Engine bay completely wire tucked
hal shocks, bmr tq arm, bmr lca's/panhard rod
stock crank
eagle rods
wiseco pistons
splayed mains
all arp hardware
1074 head gaskets
STOCK intake
STOCK TB
STOCK cam
1.6 rr's
lt4 valve springs
30x12x3 FMIC
3" charge pipe
44mm tial WG
RFL wastegate
Joe P MBC
