Turbo keeping ram air?
Old 08-13-2010 | 07:58 PM
LSWHO's Avatar
Anybody ever fabricate a lower tray for the ram air intake that would feed sideways into the turbo intake?
I will eventually be going turbo with this car, but I've never seen a turbo setup that retains the ram air intake. Have I just not come across one or am I correct to say I'd be the first? (the latter seems HIGHLY unlikely)
I could easily make one out of fiberglass... Only thing I could think that would cause an issue is the actual routing to the turbo intake and the elbow still needed into the intake manifold... but I believe these are both doable.
Old 08-14-2010 | 11:14 AM
Procharged94Lt1's Avatar
Nobody has done it probably because all the Ram-air ducting would be restriction on the the intake side...
Old 08-14-2010 | 06:04 PM
LSWHO's Avatar
In stock form, yes but the hood hollowed out and the box remade with fiberglass would pose no more of a hinderance than anything else.
Old 08-14-2010 | 07:57 PM
95z28_m6's Avatar
I would think that if you couldn't figure anything out using the hood, you could ditch a foglight or 2 and make that a ram air of sorts. If you could hook up to the ram air hood, that would really be sweet, but I think that it would be a tight fit under there.
Old 08-14-2010 | 08:02 PM
LSWHO's Avatar
Well doesn't the upright radiator make for a decent bit of room?? Somebody give me a built bottom end and their turbo kit and I'll make a ram air box out of fiberglass.
Old 08-19-2010 | 03:08 PM
97FormulaWS-6's Avatar
Still a restriction just because of the size of the holes in the hood. Trust me... I've looked into it.
Even with a custom box and debaffled hood you're still going to choke the airflow through the hood openings.
F'n1996Z28SS
08-23-2023 11:19 PM
LT14LIFE
02-09-2015 09:35 PM
rjc1629
01-27-2015 10:46 AM
TitoPR221
Parts Wanted
01-10-2015 09:21 AM
Quick Reply: Turbo keeping ram air?
