Updated LT1 single turbo pics
Old 04-21-2003 | 08:30 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Props to BW for taking/hosting the pics.
http://www.chitownsyty.com/gallery/v..._albumName=jim
Old 04-21-2003 | 09:24 PM
97SS ragtop #077's Avatar
nice.....thats my next project.
Old 04-21-2003 | 11:25 PM
Chrisbequick's Avatar
Thumbs up
Killer. Looks like you've got a great fit. Did you fab that oil pan?
-Chris
Old 04-22-2003 | 01:18 AM
got_hp?'s Avatar
is this just a custom job, or for a kit?
Old 04-22-2003 | 03:01 AM
sleepybu's Avatar
nice shop
Old 04-22-2003 | 08:57 AM
IDOXLR8's Avatar
That is an extremely nice setup.
Old 04-22-2003 | 10:04 AM
Jim S. '95 Z28's Avatar
Thumbs up
Delicious!
Old 04-22-2003 | 01:19 PM
INTMD8's Avatar
Thanks guys.
The oil pan is made by Canton.
I built the setup for my car. No plans to make a kit.
It should be on the dyno within the next 2 weeks.
Old 04-22-2003 | 03:31 PM
Guido's Avatar
Thumbs up
Lookin really good man! I hope that the tuning goes smoothly for you.
Old 04-23-2003 | 01:05 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
looks good dude! I almost did the same type of header on my drivers side, but was concerned with not being ablt to change plugs with out dropping the downpipe. how does yours look?
Old 04-23-2003 | 01:40 AM
INTMD8's Avatar
Thanks again
When I built the headers, plug/wire access was a big consideration.
All the plugs are very easy to get too. Both sides are easiest from the top, but the drivers side plugs could be changed from the bottom without removing anything.
The closest thing on the whole system is the rack/steering shaft. I only have about 1/8in clearance around my downpipe in that area, and it's 'ovalized' a bit.
Jordon- have you got your car on the dyno yet? What do you think of the setup so far in terms of fun/driveability etc ?
I'm a bit worried about turbo lag. Innovative said I won't see full boost till around 4-4500.
Old 04-23-2003 | 01:42 AM
man its fun as hell tried to dyno it, but had some problems.. figured it out tho(leaks in vacuum lines).
nothing like 500+rwtq @ 2800. I make 14psi by 3k.
what turbo do you have? Gt80?
Old 04-23-2003 | 02:37 AM
INTMD8's Avatar
Fun as hell sounds good to me
You were having boost control problems on the dyno?
My turbo is a GT80BB, R-trim, 1.32ar.
What are you running for total ignition timing? I'm thinking around 26 total will be good for around 15lbs of boost and 100 octane. I don't want to retard the timing too much because I don't know how much heat my mild steel headers can take.
Old 04-23-2003 | 09:11 AM
Guido's Avatar
Is yoru exhaust housing 1.32ar??? If so, I can understand why your turbo will lag so much. That is HUGE! Mine is .96 and Ive even got 406ci. I can tell a little lag in mine but launching it off the brakek will make up for it.
Old 04-23-2003 | 09:29 AM
sleeperz28's Avatar
Looks good. IF your running a 383 and the right cam I would not worry about spool up.
