URG :rant:
Old 01-05-2008 | 03:29 PM
LT1-TA's Avatar
URG :rant:
lol... Just got to love it...
The headers i got have thick 1/2" flanges on them, so the standard 7/8 or .750 long header bolt does not grab very many threads in the head at ALL. This is something i never thought about really before untill i pulled the threads out of one of the holes.
So I went to the local nuts and bolts warehouse place and had them find me some 3/8" 16 thread bolts that were 1-1/4 long and had the allen head (I shoulda got the normal hex head, but all the heads were too big).
I spent a STUPID amount of time getting the headers in the other day. What a complete pain pain the ***. And getting the header bolts tight with a allen and the routing of the primarys is hard as hell. With header bolts i could use a allen, socket, or end wrench. Now im very limited. I had to make a few tools to do it.
Im thinking about sellin the headers and building a new set with the primarys in a different positions. These headers are GREAT, just hard to get on. I have my car apart way to much to have them be that much of a pain Only other issue is if i build a new set of headers with a standard flange then the crossover wont fit as well (though with the flex it should still work).... Almost would need to make another kit.
Old 01-05-2008 | 03:35 PM
LT1-TA's Avatar
AND!!!! what kinda torque are you guys putting on these header bolts?? give me a number =] lol
Old 01-05-2008 | 05:10 PM
hotrod18_69's Avatar
Got any pics?
Old 01-05-2008 | 08:20 PM
97ChameleonTA's Avatar
Moderator
What about using studs and nuts instead of bolts? That might solve your problem with access and length. Just thought i'd throw that out there.
Marty
Old 01-05-2008 | 08:27 PM
Kevin Blown 95 TA's Avatar
Marty
I use ARP header studs with 12 pt nuts and can tell you that the clearance to get the header flanges on over the studs is almost non-existant. I had to shorten all of the studs to make them work. It is an absolute solid setup, though, and never loosens or leaks.
Old 01-06-2008 | 04:28 PM
LT1-TA's Avatar
The studs MAY work... It's something i'll consider. It works for now. I dont have to worry about it again untill I take it all out.
Not sure if i'll sell or just modify... But here are pics
Couple pics
Old 01-11-2008 | 08:24 PM
SMOKNZ's Avatar
Torque 'till tight I found some 1" header bolts at my local auto-parts store that worked in my case.
Bill
Hurin
12-13-2014 07:38 PM
Quick Reply: URG :rant:
