Went to Dyno today, # seem high for stock heads and cam
Old 10-22-2004 | 03:59 PM
BMAN'S SCZ's Avatar
Ya, just got back from the dyno and did 3 pulls with a wideband and had higher than expected numbers. Here we go stock heads and cam, 1.6 rr, asm headers and borla cat back with a 1/2 hole in the block off plate. 8# 600pb twin high flow IC. Done on a superflow dyno. Peak HP at 5900rpm 438.8 and peak TQ at 4900rpm was 424.8. Before I get to excited does that seem alittle high for stock heads and cam? From what I have been seeing it is generally around 400hp.It ran rich between 3300-5600 rpm, and just a hair lean at 5900 up. I know I am just in the beginning stages. I will post the sheets when I scan them in work tommorrow. Thanks for any input......John.
Old 10-22-2004 | 04:05 PM
JZ 97 SS 1500's Avatar
Re: Went to Dyno today, # seem high for stock heads and cam
Thats pretty normal for a S/C setup. Good numbers....
Jose
Old 10-22-2004 | 06:50 PM
Yby4n95Z's Avatar
Not sure about a superflow but I put down the numbers in my sig with about the same setup as you. That was on a Mustang dyno. I peaked HP at 5500 and TQ at 4500. Interested in a dyno chart if you can post.
Adam
EDIT: Auto or M6..? The M6 usually dyno a little higher.
Old 10-23-2004 | 02:57 AM
5.0THIS's Avatar
Just curious, does this motor have a built bottom end? stock compression?
Old 10-23-2004 | 05:09 PM
BMAN'S SCZ's Avatar
Stock bottom end, stock compression, heads and cam. The only thing that I changed was crane's 1.6rr with stock springs. It was also through a M6.
HectorM52
07-30-2017 11:46 AM
HectorM52
Parts Wanted
02-11-2015 09:33 AM
Killer94z
01-13-2015 12:06 PM
birdblack
12-30-2014 06:59 PM
Queens94z28
11-20-2014 06:03 PM
Quick Reply: Went to Dyno today, # seem high for stock heads and cam
