what to expect RWHP??
#31
will procharger D1SC work with vortec after cooler i've got?And Will it be allot more money to change over to procharger than just bolt on T-trim? Also are the crank pulleys completely different because im about to buy custom pulley for $275 dollars to work with ATI superdamper. BTW Call911 CR is 8:1 is this to low?
#32
#34
9.1:1 is a good ratio. It should be good for 17-18#'s. 9.5:1 is where it starts to limit you to safely run more than 17#'s or so.
#37
#38
why so much loss?
I don't under stand how this makes any sense.
some people say m6 = 16% loss and i don't know how true that is, but lets say you don't modify any thing but engine. why would the same m6,rearend,drive shaft loss so much more power now.because 16% of lets say 500fwhp is much more than 16% of 300fwhp?
#39
why so much loss?
#41
Its all good. Cars loose power due to the transfer of power from the motor through the transmission and driveshaft through the rear to the wheels, and then to the ground. But I think you are trying to understand "why" the loss is that much, and I don't know the answer to that.
#42
blown cars also loose as much as 80-100hp on top of the drivetrain loss due to the belt and how hard the motor has to turn in order to turn the blower. the biggeer it is the bigger the loss. So if you putting down 650 through an auto and a 12 bolt, add your drivetrain loss and then add your blower loss and that is what your motor is actually seeing.
