What IATs are you guys seeing?
Old 10-02-2004 | 08:24 AM
  #31
tubby's Avatar
Re: What IATs are you guys seeing?
my last run started at 150 ended at 213. 17# boost 6,200-6,500 rpm.
Old 10-02-2004 | 08:55 AM
  #32
2MCHPSI's Avatar
10 PSI with S Trim and Aftercooler I saw on an 85 degree day IATs just under 100 degrees at WOT. It dropped to 90 degrees in regular driving.. Traffic, it might have hit 105.. No heat soak from my setup..I just used a 50/50 mix of antifreeze, water and only modifications were a larger pump for the aftercooler.
Old 10-02-2004 | 09:16 AM
  #33
Alvin@pcmforless.com's Avatar
A 35mph to 80mph run only raises the IATS by about 10 degrees..
This is a T trim aftercooled on 9psi.
Old 10-04-2004 | 10:22 PM
  #34
Sneakin Deacon's Avatar
went to the track yesterday and my friends non intercooled setup staged around 140, and through the traps was at 90...i really like his alky kit, it seems to really help cool things down, not to mention prevent some detonation.
Old 10-26-2004 | 10:46 PM
  #35
Highlander's Avatar
Mine is about 4.5 inches thick... and its a2w... z8s (who was the previous owner) said: that he started with ice on the tank and by the time the 1/4 was over the water was boiling!!!
Old 10-27-2004 | 12:00 AM
  #36
texlurch's Avatar
16 psi with twin FMIC A/A, start was 110, finish was 158, 90-92 deg. outside. Timing was 18 deg, seems to run better at around 26 now.
HectorM52
07-30-2017 11:46 AM
carguy0119
04-11-2016 11:11 PM
BinkZ28
04-20-2015 09:10 PM
grabbem88
02-13-2015 03:09 PM
Red97LT1
08-07-2002 05:45 PM
Quick Reply: What IATs are you guys seeing?
