Whats the smallest 8 rib blower pulley you guys have used with no slip?
Old 11-23-2004 | 03:44 AM
CoUnTryMuZiCZ28's Avatar
This is a vortech T trim.. I was trying to find a bigger crank pulley but was unsuccesful at finding one at anywhere near a decent price. So I decided to go with a smaller blower pulley but the one im running now is a 2.75 and im seeing 10psi sometimes 11. I dont believe the belt is slipping but it is a possibility (anyway to check?). I was thinking Im going to go with a 2.65 or 2.55 blower pulley. I dont know if slippage will be an issue though.. whats the smallest you all have used? Know of anyone selling a 7" crank pulley?
Old 11-23-2004 | 06:08 AM
john35thss's Avatar
Re: Whats the smallest 8 rib blower pulley you guys have used with no slip?
Look for rubber on the head unit. I was using a 7.2 that I had machined with a 3.12 on my v2 with no slip, I did use a belt condtioner when I first broke the belt in. Vortec no longer makes a 7, I bought one used hard to come by. Not sure if anything bigger than a 7.2 will work not much room under there.
Makes more sense to increase crank pulley than decrease blower if trying to avoid belt slip.
John
Old 11-23-2004 | 07:09 AM
John
any other ways of checking for belt slip??
Old 11-23-2004 | 10:06 AM
Pro Stock John's Avatar
What are you trying to accomplish?
On my LS1, I run:
8.00 Vortech base kit crank setup
2.85 Vortech blower pulley
Custom manual tensioner
I saw 17 on the dyno, but had some slippage and bracket flexxing issues. so I was only seeing 14-15 psi at the track with the YS.
I added a strut brace so I hope for some new big numbers and less belt problems.
Old 11-23-2004 | 02:29 PM
chevyguy3's Avatar
asp makes (or at least used to make) a 8" 8-rib crank pulley. i was using that along with a 2.95 blower pulley and had no slipping problems at all @ 17-18psi on a t-trim. you have to grind the blower belt tensioner some and re-position the fans slightly forward/upward if you are using stock fans to clear the 8" pulley. i wouldnt go any smaller than where you are at on your blower pulley unless you go to a 10-rib setup
Old 11-24-2004 | 05:01 PM
JAY'S 91Z's Avatar
I'm running a 6 1/2" crank pulley and recently upgraded to a 2.65" blower pulley. I'm getting 12 pounds and when it slips I can feel the car kind of bucking or falling on it's face for a split second. It's hard to explain, but when the belt slips under boost you feel it and sometimes you can smell it. I have always been able to solve the problem by re-tensioning the belt, but if it slipped bad it should be replaced as the belts can glaze over from the heat.
BTW I'm running a p600b with an 8 rib setup.
Old 11-24-2004 | 08:09 PM
Whats your compression ratio for that 17psi of yours.. lol.. mines 8.5:1.. Im gradually upping the boost...
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
SpeedJunkee
01-27-2015 10:02 PM
1LEThumper
07-14-2003 12:45 PM
Red97LT1
08-07-2002 05:45 PM
Quick Reply: Whats the smallest 8 rib blower pulley you guys have used with no slip?
