Wideband users, whats ideal AFR? Whats dangerously lean?
Old 05-15-2010 | 08:46 AM
  #16
CALL911's Avatar
Originally Posted by blown94
How does the alky kit bleed off boost if the pump doesnt run? Ive never seen/heard of this and id like to know more.
Secondly, does your little light tell you that power has been applied to the pump, or is it the setup that lights up if the pump isnt drawing the current? Because a light that tells you the wire is hot wont tell you the pump isnt pumping. Thats my biggest fear with the meth, and I have good reason since I had a meth line meltdown failure and it took out my head gaskets as a result of detonation.
Its a Snow Performance Kit (not Alky Control). Go to their website, or give them a call for more info on it if you want.
You can rig up the light however you want. However what I use and believe works best is to set it up not to the pump but to a sensor that actually senses the meth flowing. I have another light also rigged to show me when my meth level is getting low.
I did a few more runs last night, and did notice that the wideband does tend to float around while in the upper boost. This is no doubt because of the increase in meth as the increase in boost. I did see it climb to 11.9 at one point very momentarily, and I didn't really care for that. I have heard some running a tune that lean, but I you have felt better if it didn't. This was really only for a fraction of a second, and most of the wideband readings were back to the 11.5 range.
Perhaps I'll consult my tuner.
Old 05-15-2010 | 11:58 AM
  #17
blown94's Avatar
Originally Posted by jsetzer
You can get a device that actually plugs into the feed line and detects flow.
They can be pretty safe. I'm shopping them now. Can't make up my mind - either run corn or do meth.
Ive done some reading on that already, it seems the meth is the cheaper route in the long run if you buy in quantity i believe.
Old 05-22-2010 | 11:25 PM
  #18
LT1-TA's Avatar
11.8 is a ideal afr imo. I wouldn't push it past 12.
Safe afr without losin too much power to a rich tune would be 11.5
Less than that is just too rich and your wasting fuel and giving up power.
RUENUF
03-13-2016 03:39 PM
MadMav
06-15-2015 09:51 PM
Fastbird93
05-22-2015 08:28 PM
Russ95Z28
04-23-2015 01:55 PM
MadMav
02-06-2015 11:02 PM
Quick Reply: Wideband users, whats ideal AFR? Whats dangerously lean?
