Will this cam work?
Will this cam work?
I'm picking up a PSC-1 this weekend for my car. This spring I am getting the block bored .030, have forged components installed, 1.6 RR, comp R lifters, LT4 intake/heads, 58mm TB. I'll be running an 8# pulley and a small shot of nitrous.
Last year I bought a XE230-236 cam for just a nitrous motor, a friend is selling the SC at a great price and I can't pass it up, here are the specs of the cam:
I E
Adv Duration 282 288
Dur @ .050 230 236
Lift w/ 1.6 .544 .555
LSA 112
Will this cam work for my set-up? Procharger's website suggests LSA 112-116 (where this is at) and split pattern: exhaust duration and lift approx. 10 degrees and .010, respectively, greater than intake.
I'm still new to all these cam numbers and trying to learn as I go.
I E
Dur @ .050 230 236
LSA 112
Re: Will this cam work?
I E
Dur @ .050 230 236
LSA 112
I E
Dur @ .050 230 236
LSA 112
Originally posted by stealth2
Call Comp and ask them to spec a cam for you. When in doubt, ask a professional.
Thanks for the responses, except for Ryan's. Yes, I own an old Civic, but I'm not proud of it (not riced out at all!)
Mike
Originally posted by engineermike
They guys who answer the phone at Comp are not professionals. They get paid minimum wage to look up cams in a catalog. Unfortunately, the real experts at Comp are not available to the general public, except for a [much higher] price.
Mike
Mike
BTW: two degrees of lobe separation can make a noticible difference in a cam.
Rich Krause
The only way to determine the cam that works best for your setup is to test it on a dyno or track, which is why the big boys buy cams a dozen at a time. The next best alternative is have a professional cam grinder design one for you based on his experience and expertise. The wrong way to do it is ask people at a web site. That's my opinion.
Highlander, since there are no mods in your sig, I will only say that John Lingenfelter put a lot of lobe separation in his LS1 and LT1 cams, so 116 or 117 might make some sense. I run 114 with 4 degrees advance in my blown LS1.
Im not from texas, im from PR but in that time there were a lot of people inquiring about my car locally on the forums and im a bit suspicious
I have a 383 AFR 190 heads (soon to be 210s) 224/236 cam with 114lsa (soon to be 116).
with 8 psi boost and a worn impeller
http://netdial.caribe.net/~highland/impellerc.jpg
I did 555rwhp on a mustang dyno
517rwtq.
With 10psi was 607rwhp.
This was all with an S-trim.
I also run 4 advance ground up on the cam.
This year it will be a T-trim the cam and the heads so basically a new setup... expect around 650 on pump gas.. no less.. and I hope and/or wish to reach 700rwhp.
517rwtq.
