Work in progress...long... 56K users beware!
Old 01-13-2006, 05:22 AM
  #16
LameRandomName's Avatar
Re: Work in progress...long... 56K users beware!
Originally Posted by blown383
Engine guy said that it'll take roughly 2 weeks to get the long block back
How much of that time will be taken up in extracting the engine from the front seat?
LameRandomName is offline
Old 01-14-2006, 08:01 PM
  #17
turbo_Z's Avatar
Guess you make due with what you have available... But I do highly suggest you find a pickup to bring the motor back home.
turbo_Z is offline
Old 01-14-2006, 09:31 PM
  #18
BruceVette's Avatar
Dude man.
If you can't bother a friend's truck. I would suggest to rent a small
U- Haul truck for $19.99? it well worth the money.
BruceVette is offline
Old 01-15-2006, 12:25 AM
  #19
Chrisbequick's Avatar
I tried to use the Racetronix single intank on my turbo setup and it was leaning out bad on the top end with just 50 lb. injectors. If you're planning a motor that needs 83s you'll need a lot more pump. FWIW I added an inline Bosch pump and the combination of the two pumps is feeding my 355 with 11 psi and 60 pounders to 560 at the wheels no problem.
-Chris
Chrisbequick is offline
Old 01-17-2006, 10:02 PM
  #20
LWM
LWM's Avatar
That picture of the engine in the passenger seat ... truly raised the bar to virtually unattainable heights ...
Did it bend the car??
LWM
LWM is offline
rideordie
11-05-2019 04:52 PM
Jlo
02-03-2015 09:41 PM
1996LT1Z28
Middle Atlantic
12-04-2014 09:37 PM
1996LT1Z28
12-04-2014 09:20 PM
BIGCOWL-IMP
11-21-2014 09:40 AM
Quick Reply: Work in progress...long... 56K users beware!
