Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
30# injectors installing
Old 08-12-2008 | 09:58 AM
94 Sunburst formula's Avatar
Ok I went to install a rebuilt and flow matched set of injectors. As i was putting the 3rd one in i noticed the 2nd one was dripping gas. I thought maybe some gas ran down it while i was puttng it in the fuel rail, nope its dripping out the pintle cap. My question: Is this injector junk, is this normal, should i go aheadnd install them and see what happens? The injectors are ford racing svo injectors red top with shinny bodies.
Old 08-12-2008 | 05:46 PM
Was it dripping with no pressure on the rails? If so, with all the injectors in place, prime the fuel pump to build up 40psi in the rails. If it continues to leak, it is defective.
Old 08-12-2008 | 08:13 PM
Ya it was dripping with no pressure. I put the old ones back in and stopped there till i got some definate answers.
10-31-2016 11:09 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
07-04-2005 05:00 PM
Wilson
07-21-2002 05:08 PM
Quick Reply: 30# injectors installing
