Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Ignition switch or cylinder bad??
Old 07-17-2013 | 06:12 PM
thoreightysix's Avatar
Exclamation Ignition switch or cylinder bad??
For the last week I have had intermittent 'normal' starts. When I turn the key back and forth, it seems as though it helps and will start fine 20 times in a row. No problems stalling in traffic or anything like that, when it runs...it runs. It has a new fuel pump, pressure is where it should be. I am quick to guess the ignition switch or cylinder, because one time it felt locked/ hung up...I forced it ( like an idiot) and now it doesn't have operation when turned in the backward position. Between these intermittent starts, I can sometimes hear a click.
Any help would be much appreciated, I don't want to get stranded anywhere. Thanks.
Old 07-18-2013 | 08:42 PM
Re: Ignition switch or cylinder bad??
The ignition switch is a more common problem than the cylinder hanging up.
Take a look at the replacement guide on my website. Click the how to's link in my sig.
Old 07-19-2013 | 12:36 AM
Thanks shoebox; Yoda of the LT1! I've been going through your tech article for some time now, looks easy enough to do.
Any tips on changing this switch out?
Old 07-20-2013 | 07:36 PM
It was indeed the ignition switch. Thanks again shoebox.
Oh ya...easy to install!
10-31-2016 11:09 AM
Heathen1
01-02-2016 04:27 PM
kallcium
V6 Tech
10-07-2015 03:39 PM
robcarnut
03-20-2015 03:40 PM
Oncomingstorm22
01-22-2015 07:15 PM
Quick Reply: Ignition switch or cylinder bad??
