Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
lt1 no spark
Old 05-22-2011 | 06:57 PM
scottnorton's Avatar
lt1 no spark
Ok i've searched all over the web i rarely ever post, but my issue is that my 95 lt1 with msd blaster coil, 6al, ac delco opti wont start just cranks and cranks. ran fine when I pulled it into the garage the next day nothing ive tested the msd box it came out fine. Ive tested voltage to the icm i have 12v to A and to D also I have 4v AC to b while cranking but have no spark at plugs or coil any ideas im at a loss thanks guys.
Old 05-22-2011 | 07:50 PM
Re: lt1 no spark
Did you check the coil? Did you have the IC module tested?
Old 05-22-2011 | 08:14 PM
Re: lt1 no spark
ive swapped out icm with a friends and same deal how do i test my coil?
Old 05-23-2011 | 06:53 AM
Re: lt1 no spark
Coil winding continuity test.
Old 05-23-2011 | 05:44 PM
Re: lt1 no spark
thanks shoebox i tested my msd coil came up with 5.382 ohms at all 4 points ive tested the opti with the information on your page I had 10v on terminals a and d, an 4v ac on terminal b while cranking. Im not sure it isnt my opti though i was bleeding my coolant after a vertical radiator swap and the car started fine 3 times... I pull it in the garage it sets for 3 days and i get no spark is it possible that the antifreeze got into the opti while setting and still test out ok? also icm i swapped out with a friends with no difference and disconnected my msd 6al. An still nothing any ideas guys?
Old 05-23-2011 | 09:25 PM
Re: lt1 no spark
update got car running tonight swapped out with another used icm but runs like crap now not sure if it could be wet opti or junk icm the car cuts out at high rpm and is smooth at idle but will randomly try to die. ideas
Old 05-30-2011 | 02:02 PM
Re: lt1 no spark
ok so my car wont stop frying icm anybody have any thoughts?
Old 05-30-2011 | 02:09 PM
Re: lt1 no spark
Check the current thread on the LT1 Based Engine Tech forum, with regard to relocating an ICM that was being severely overheated in the stock location, apparently due to the use of non-coated headers.
Old 05-30-2011 | 09:04 PM
Re: lt1 no spark
also i never put any of the heat transfer lube on would this cause so many to go out right away?
Old 05-30-2011 | 09:23 PM
Re: lt1 no spark
Might.
Are your Hooker LT's cera-metallic coated?
Old 05-30-2011 | 10:32 PM
Re: lt1 no spark
No there not coated but the first one lasted so long now I can keep them working
Old 08-04-2012 | 04:33 PM
OnTheGlass's Avatar
Re: lt1 no spark
Hi Scott, Did you ever solve this problem with the crank no start? I'm having the same issue with my 1994 Trans A/M. I have stock coil, stock ICM, both which I replaced a few years ago. My Optispark went out about 6 months ago so I got the MSD all billet Opti, put it in with new water pump. Car ran better then it ever has super happy with the MSD Opti. Then one day no start just cranks just like you posted. Did you ever solve your problem? I have checked everything to the best of my ability and still nothing.
Old 08-04-2012 | 05:03 PM
Re: lt1 no spark
"scottnorton" has not been active on the site for 3 months. You might want to send him an e-mail.
Have you scanned it for codes? Have you checked the fuel pressure? Did you Loc-Tite the MSD Opti rotor screw before installing it? Have you verified spark or no spark at the plugs? ..... at the coil?
10-31-2016 11:09 AM
ch3vyb1gbl0ck
01-28-2015 04:45 PM
FIREBIRDMARK1
01-07-2015 03:36 PM
Hot Rod Hawk
08-30-2002 10:12 PM
DubbyZ28Camaro
08-04-2002 12:53 PM
Quick Reply: lt1 no spark
