Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
lt1 spark plug wire suggestions
Old 06-13-2010 | 07:01 AM
hamburgerler
Guest
Posts: n/a
hi guys im new to lt1's and the site and after a bit of reading its seems burning wires are a constant. I just aquired 94 z28 and im just trying to find the most effective way to keep plug wires on with pacesetter headers on. I know of the otvc, but are there any other effective ways that will work?
Old 06-13-2010 | 05:09 PM
Kevin Blown 95 TA's Avatar
Good quality Accells or MSDs will work, but you still need to protect them from the headers somehow. The fiberglass boots are a big help, but the important thing is to carefully route them away form the headers and tie them out of the way somehow to anything that is handy to keep them away from the immediate heat. You can put sleeves or high heat split loom on the wires for abrasion resistance which helps when you tie them to brackets and stuff, but sleeves can keep in moisture if your car gets wet often.
Old 06-13-2010 | 09:58 PM
hamburgerler
Guest
Posts: n/a
thanks for the info. im actually looking at the taylor full metal jacket as a solution. might still help tp tie them out of the way as well.
Old 07-30-2010 | 09:16 PM
Paul94Z28's Avatar
You may think I am crazy
I run pacesetter long tubes over new stock 7mm wires in the factory looms with no issues. I use the stock metal heat insulators over plugs 5 and 6.
No Issues.
Jazsun
12-29-2014 12:14 PM
BIGCOWL-IMP
11-21-2014 09:40 AM
sleeperZ96BT
06-05-2005 09:33 PM
DubbyZ28Camaro
08-04-2002 12:53 PM
Quick Reply: lt1 spark plug wire suggestions
