problem with 96 camaro not starting after warmed up
This is what I have, A 96 camaro z28 5.8LT1. I can start the car, after it warms up , and i stop somewhere and turn it off, it wont start again.
It sounds like it isnt getting gas or spark. what can it be?
Re: problem with 96 camaro not starting after warmed up
I am having a similar problem with my 96. After I stop and try and restart the vehicle it will not start unless I hold the accelerator to the floor. Have you figured it out yet?
Holding the accel pedal to the floor puts the PCM in "clear flood" mode. Could be a problem with leaking injector(s), or possibly a coolant temp sensor that isn't correctly telling the PCM the engine is warmed up and doesn't need the enriched cold start.
