Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Sometimes car needs to be started 2-3 times!
Old 10-16-2008 | 12:08 AM
ItalianSS's Avatar
Hey guys, i'm use to getting into a car, starting it up, and it running. Now i started having a problem with my car, that gets kinda annoying especally if people are around. If i jump in my car, and start it up... sometimes it just shuts off! Then I have to deal with people looking at me, and asking what's wrong with your car.
Now: If I get in my car, turn the key to the on position, and wait two to three seconds, then turn the key the rest of the way... it always starts without a problem.
What could be going on?
Sometimes I go turn the key and there is no click or nothing, like no power.... if I pause for a second or two, then turn the key again... it starts! WTF???
Loose battery cable? I checked
Dead Battery? Had it replaced last year
air filter dirty? Changed the set up to a Volant intake.
Anything i'm over looking? Thanks guys/girls
Old 10-16-2008 | 02:32 PM
mrmint69's Avatar
Fuel pump could be going out. Check the fuel pressure first. If the fuel filter is old you should replace that also.
Old 10-16-2008 | 03:17 PM
Could also be a problem with the ignition switch.
Old 10-17-2008 | 02:19 AM
ItalianSS's Avatar
Well I had to change the fuel pump at 55,000 miles. I'm at 80K and I strongly think its not that.
Old 10-17-2008 | 02:20 AM
ItalianSS's Avatar
Ignition switch huh? How can I check that out? Thanks
Old 11-28-2008 | 03:05 PM
jcurrieirocz's Avatar
read this if your going to replace it: http://shbox.com/ignsw/ign_switch_repl.html
Old 11-28-2008 | 05:08 PM
Never assume that because you replaced the fuel pump it isn't going to die in a short period of time. The Walbro's seem to be notorious for failing due to dirty fuel.
Louey
Pacific
12-25-2014 03:27 AM
Louey
Pacific
12-08-2014 08:01 PM
Louey
Pacific
12-01-2014 04:16 PM
Louey
Pacific
11-28-2014 03:46 AM
USAirman93
11-24-2014 03:37 PM
Quick Reply: Sometimes car needs to be started 2-3 times!
