Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Starter not cranking...PLEASE HELP!!
Old 06-21-2010 | 06:51 PM
69CamaroProT's Avatar
Question Starter not cranking...PLEASE HELP!!
I have a 1969 camaro that i am restoring. Here is my issue. I stripped my interior and removed my instrument cluster to sand down and remove all the rust in my interior. After completing the inside paint, i connect the grounds under dash (without connecting the gauges) and connected the battery terminal. Now my car wont crank. I turn the key and nothing happens to the starter however when i turn to crank position, the TEMP light flashes. The car started up just fine before i took my interior apart. I have a fairly new fuel pump also. It seems as though the car was an original automatic but the previous owner converted to muncie 4 speed so im not sure if its a neutral safety switch issue (i do not see a safety switch on my clutch pedal). Any help diagnosing this will much appreciated.
Old 06-22-2010 | 07:44 AM
Sounds like you need a wiring diagram. Normally there is a purple wire from the ignition switch that goes to the S terminal on the starter solenoid. It must have 12v when the key is in the START position for the starter to engage. I would be checking that out.
Formula Steve
09-19-2023 08:31 AM
Rod Bender
25
09-16-2015 01:47 PM
jackpawt883
09-10-2015 08:53 PM
4586
08-18-2015 07:08 AM
realistyc
07-28-2015 07:32 PM
Quick Reply: Starter not cranking...PLEASE HELP!!
