Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
STILL stuttering and skipping....
Old 11-25-2008 | 11:21 AM
BLAKE1979's Avatar
Angry STILL stuttering and skipping....
My 95 Z28 is STILL skipping and stuttering. I have changed the plugs, wires, distributor and fuel filter. I've also have had diagnostic checks with scanners, fuel pump tests, the egr checked etc... Still I've had no luck figuring out the exact problem is. This started about a year ago. Sometimes it runs problem free and then sometimes it run's really bad. High and low rpms. The passed few weeks have been up and down. It will skip and stutter one day, and then seem race ready the next. The engine was replaced with a new LT1 back in June of 2003. So the engine itself has about 60 or 70000 miles on it. Any feedback will be GREATLY appreciated.
Old 11-25-2008 | 08:04 PM
max_ta's Avatar
opti or try the temp sensor in waterpump first
Old 11-25-2008 | 11:25 PM
Does the problem increase on damp days? Does it correlate to ambient temperature at all (e.g. - worse when cold)? Have you checked the Opti harness connectors (there are two of them) for corrosion and/or damaged pins?
When it was scanned, were you just looking for codes? Or did you do a data log? If you did a data log, do you still have it?
Old 11-26-2008 | 01:10 AM
Fatdog2's Avatar
Map sensor?
Old 11-26-2008 | 07:36 AM
BLAKE1979's Avatar
Ive had my mechanic check the opti harness and connectors and said that they looked fine. What about the map sensor?? What does that control? My friend works for a race shop and he checked it with 2 or 3 different scanners. It wasn't throwing any codes. It also doesn't really matter whether it's damp or dry outside. It does it in both types of weather.
Old 12-08-2008 | 03:30 PM
BLAKE1979's Avatar
Cool Thanks.
I will have to try the temp sensor then. Already replaced the opti. Man I tell you Ive tried almost everything with no luck!! What if the temp sensor doesn't fix it? Any other suggestions?
Thanks, Blake
Old 12-09-2008 | 08:06 PM
max_ta's Avatar
what injuneer said
buggy323
07-01-2015 04:37 PM
C Man
06-23-2003 10:35 AM
speed76demon
04-08-2003 01:38 AM
speed76demon
04-07-2003 07:54 PM
JSK333
03-13-2003 09:13 AM
Quick Reply: STILL stuttering and skipping....
