stock injectors??
More than you might want to pay. I don't know about the 93 22 #/HR injectors, but the GM dealer list price on the 94+ 24 #/HR injectors is $161.27 EACH ($1,290 for a "set"), according to gmpartsdirect. Their discount price is $83.86 each + shipping. At those prices, its hard to justify OEM at almost $700 for a set of 8 injectors, when you can get others of decent quality for less than 1/2 of that.
You could have the injectors cleaned and flow balanced. The price can be as much as $40 at someplace like TPIS. For that price, if they find an injector that is bad, or one that is too far out of tolerance for flow balancing, they will substitute a used unit from their stock. That's still $320 for a set of 8. You can get a new set of SVO's for less than that.
http://www.tpis.com/index.php?module...egory=Services
You would probably need to have a chip burned with the new injector flow constant, if you upgraded to 24 #/HR injectors. They actually flow closer to 25 #/Hr at the LT1 fuel pressure setting. Might get by without a tune, might not.
Check the vendors listed under the Supporting Vendor Index, linked at the top of every page.
10-31-2016 11:09 AM
stockssn2o
05-25-2015 08:54 AM
