1/4mile question
Old 01-15-2011 | 10:51 AM
jdelaprida's Avatar
1/4mile question
I have a 96 camaro z28.
Its automatic has 88k on it.
I have a cold air intake and a slp loudmouth II.
Does anyone no about exactly what i would run with just those 2 things?
Old 01-15-2011 | 10:08 PM
Procharged94Lt1's Avatar
Re: 1/4mile question
Depending on elevation and track prep probably flat 14 or just into high 13's. Upgrade suspension, drivetrain etc. and mid 13's should be attainable.
Old 01-16-2011 | 11:46 AM
bill2129's Avatar
i think high 13s. i really depends on who is driving the car though. if you really need to know just take it to the track
Old 01-16-2011 | 08:58 PM
jdelaprida's Avatar
i am in the spring time.
i just wanted to no cause theres alot of hondas in my town who think they have 12 second cars when i beat them...
Old 01-16-2011 | 11:36 PM
It will depend on which rear axle ratio you have. If you have the 2.73 rear axle (base ratio), its not going to be as fast as if you have the 3.23 "performance rear axle" ratio. You can tell by looking at the build code tag in the glove box - 2.73 is "GU2"; 3.23 is "GU5"
Old 01-17-2011 | 06:37 PM
jdelaprida's Avatar
i have the gu5 3.23
Old 01-17-2011 | 09:44 PM
Personally, based on the road tests I have from when these cars were new, they were not 13-second cars when stock. With a really good driver, and a really sticky set of tires, and a good launch, you might get into the 13's, but I never saw it happen. The magazines were getting mid 14's to low 14's. That's what I'd expect a stocker to run. With the CAI and catback, 14.0
Old 01-17-2011 | 10:47 PM
jdelaprida's Avatar
whats a simple mod that would get me under 14s in 13s?
Old 01-18-2011 | 12:06 PM
Z28SORR's Avatar
Change the rear gear ratio to 3:73 or 4:10. Most guys with Auto's like the 3:73 gear.
Old 01-18-2011 | 02:05 PM
jdelaprida's Avatar
wheres that going to put me with 3.73s
Old 01-19-2011 | 10:53 AM
Z28SORR's Avatar
Should be around .5 sec. quicker.
Old 01-19-2011 | 12:15 PM
AutoRoc's Avatar
A friend of mine went 13.95 @100 with an automatic, 2.73 geared, 1996 trans am. Cold weather. It had a K&N cold air and welded in flowmaster muffler. Funny thing is, it was nearly impossible to do a good burnout because of the gearing. It barely made it to 3rd gear in the 1/4. The 1-2 shift looked to he at the damn 1/8th mile.
In hot weather, stock, it ran 14.4 @97-98mph.
Old 01-20-2011 | 03:34 PM
Greed4Speed's Avatar
Some good soft tires so you can take complete advantage of the available power, and seat time.
dluna333
15
03-13-2015 12:30 PM
jasonduaine
03-07-2015 09:44 AM
95z_28_camaro_4_Ivan
12-19-2014 08:48 PM
Hurin
12-13-2014 07:38 PM
MellowYellowZ
08-07-2002 03:10 PM
Quick Reply: 1/4mile question
