12 Bolt Questions
Old 09-21-2004 | 05:05 PM
Mitch666's Avatar
12 Bolt Questions
I am about to get a 12 bolt for my upcoming head and cam combo. Where did everyone get their 12 bolts from? How do they ship it?? Is it put together or what?? And what gears?? I was thinking about 4.10s because my car doesnt get driven much anyway, so it wont be that big of a deal. Also how hard is it to install them?
Old 09-21-2004 | 05:50 PM
HBHRacing's Avatar
Re: 12 Bolt Questions
This will probably end up in drivetrain section but..
it depends on what you want. the 2 largest supliers are Strange and Moser. I went with Moser. It;s a great product. I got mine on a GP from TT performance (who I will NEVER EVER EVER do bussiness with again) but it came directly from Moser. It comes in a box, and that box is attached to a crate. It's sent by truck.
It's all up to you for options that you select. but the way I see it if your going to spend 2 grand on a 12 bolt you might as well get all the goodies. That for a moser inclused, the rear, performance cover, 33 spline eaton posi upgrade, ABS setup etc etc. It comes to you with the center assembled. All you need to do is take the caliper brakets off your old rear, and install them on the new axles when you press the bearings on the axles. The instructions show how. Then it;s just the minor things of getting everything set. You can find a few online guides that will help along the way.
as for gears. if you are an M6 go for it. I did and I love them. Throttle responce is geat and even when I ran from huricane Ivan I was more then comfortable driving from louisiana to NC this week. and this is my daily driver as well.
As for the install like I said look up a guide. It;s not bad. it would have taken me about 4 hours if not for the fact that they ordered mine as a 2000 instad of a 96 which meant that they didn't include the axle shims that I needed (just one reason tt performance pisses me off) and of course with any install there is always a little bit of custom fabing that you have to do but it;s really not bad
Old 09-21-2004 | 07:31 PM
justahoe's Avatar
Got mine from tybrne on a gp.. its a strange and love it complete direct bolt-in. and went with 3:42's but mines an auto.
Old 09-21-2004 | 07:39 PM
87DJP2001's Avatar
Just remember to paint it before installing. All that money and it comes unpainted and the brakes are additional plus everything else. So look to spend big bucks.
Old 09-21-2004 | 08:44 PM
HBHRacing's Avatar
I spent 2,242 for the rear and maybe another 100 on things like U joint, fluids, paint, etc etc.
Old 09-21-2004 | 09:28 PM
Mitch666's Avatar
What is the you joint? Does anyone have any rear end install guides?
Old 09-22-2004 | 06:46 AM
87DJP2001's Avatar
From your original question & the one above, I suspect you should do a little more research before thinking about a 12-bolt. Just my opinion.
Old 09-22-2004 | 11:21 AM
Grover's Avatar
I got mine through a Tbyrne group purchase from Moser. It came shipped by truck on a pallet and needed to have the brake backing plates put on the axles and then the bearings pressed on and assembled.
Old 09-22-2004 | 12:24 PM
I have the Strange... bought it from T. Byrne. Shipped fully assembled, with fluid, and with "cross-over" U-joint of your choice. Direct bolt-in except for two tiny issues.
Check out my online guide:
http://members.aol.com/InjuneerZZ/Strange12.htm
Yes, paint it first - I like my "2-tone" version:
http://members.aol.com/InjuneerZZ/im...otos/axl09.jpg
Sergio
01-27-2016 04:27 PM
maybe2fast
03-16-2015 09:45 AM
mikey4play
03-15-2015 11:45 AM
ChrisFrez
01-18-2015 08:05 AM
ChrisFrez
01-11-2015 03:47 PM
Quick Reply: 12 Bolt Questions
