17" wheels
17" wheels
What do I have to do to make my speedo accurate with my 17 wheels and 275/40/17's ? Also SES light comes on when I am cruising at 60 then coast a while How can I figure it out cheap? Or should I just buy a code reader? WHich one?
Re: 17" wheels
275/40/17s should have the same diameter as the stock wheels. so there is no need to fix the speedo.
since you have an obd1 computer you can get a cable and connect it to a laptop or desktop (if you can get it close enough) and use free software to read the codes and sensor info.
some parts stores use to scan for free. call around
Re: 17" wheels
Originally Posted by enzo1267
they are off by about a half inch. you need to correct the speedometer
Re: 17" wheels
A Hypertech Power Programmer will let you adjust for tire diameter .25" at a time but is limited for engine programming for the price ($325). The cable/laptop/software option is the best for adjustability of engine parameters. The cables are around $70 last time I checked and if you have a laptop or can borrow one would be great. Search for LT1Edit for more info.
Advance Auto Parts and Auto Zone are two chains that will scan codes for you for free, though there's no guarentee the scanner will work. . . I had my 2000 Zr2 Blazer scanned one day and the code cleared. When the SES light came back on 4 days later, I replaced a simple part that may have been the cause (gas cap) and asked them to scan and clear the code. The guy couldn't get the reader to work and blamed it on the truck.
Z28Nut
Z28Nut
30th Anniv Z28
08-01-2015 10:39 AM
jasonduaine
06-04-2015 09:29 AM
