1996 camaro light problem
Old 01-22-2011 | 11:23 AM
CamaroMan1987's Avatar
does anyone know where the power accessory relay is located in a 96 z28 camaro.. no light work on the back of the car tail light brake lights reverse lights or turn signals.. don't know what else to do.. please help
Old 01-23-2011 | 06:14 AM
Guest47904's Avatar
Guest
Re: 1996 camaro light problem
There is no "accessory relay" and there is no relay period powering the lights at the rear of the car.
Most of them are powered by the same fuse #5. A 20amp located in the I/P fuse panel.
For turn and B-U that is fuse #2 a 15 amp and for Stop/hazard that is fuse #1 a 20amp both located in the I/P panel as well.
If more than one of those is blown, it probably tells you it has a catastrophic wiring issue. If the car ever had body work, start looking in that area.
globalprojeff
12-06-2014 04:18 PM
globalprojeff
Wheels and Tires
12-06-2014 04:09 PM
sleeperZ96BT
06-05-2005 09:33 PM
JasonD
07-15-2002 02:17 PM
Quick Reply: 1996 camaro light problem
