1997 Z28 front driver side turn signal doesn't blink
Old 06-05-2010 | 06:11 PM
curlyfroman3's Avatar
I have a 1997 Z28 camaro and the front driver side turn signal will not blink. No other problems with lights and have checked all of them for corrosion or bad wiring. I replaced the socket for the turn signal light but this did not seem to help. The running light will work fine (the lower filament that connects black to brown wires). The higher filament is intact but will not light up. Tested the light blue wire that connects to the black (live wire) through this socket and it doesn't seem to be getting enough current. I used a volt meter and ran the turn signal to get a measly .2 V. I can't seem to find anything about this or how to fix it so any help would be appreciated.
Thanks!
Roach
Old 06-07-2010 | 10:04 AM
Z28SORR's Avatar
Sounds like there is nothing left to check except the wiring. Good luck.
Old 06-13-2010 | 03:09 PM
z28boycali's Avatar
i say change the sockets again.
Old 06-13-2010 | 09:25 PM
OBE1 95Z28's Avatar
Could be a bad turn signal relay. Cheap part and easy to replace.
Old 06-14-2010 | 10:17 AM
Z28SORR's Avatar
If the relay was bad none of the lights would blink!
Old 06-14-2010 | 02:51 PM
OBE1 95Z28's Avatar
Not true; my left turn signal was fine and my right did not flash; replaced the relay and now both work properly. If they didn't work independently then you would have both flash everytime (like your hazards).
Old 06-15-2010 | 09:39 AM
Z28SORR's Avatar
You'd better look at your wiring diagrams. You have two relays(flashers) one for the blinkers and one for the hazards. If your turn signal worked after you changed the flasher it was because you got lucky. There was probably a wiring problem.
http://www.howstuffworks.com/turn-signal.htm Check page two.
Old 06-15-2010 | 11:13 PM
OBE1 95Z28's Avatar
I stand corrected Thanks for correcting my my error.
Old 02-16-2012 | 10:48 AM
Colebert23's Avatar
Re: 1997 Z28 front driver side turn signal doesn't blink
I know this is a really old post, but I found a fix that might work for some people. I have a 1997 Z28 Camaro. My blinkers would work intermittently the front blinkers would just go dark when i would try to signal. The back would just go solid. I FINALLY found something that worked.... (mostly) There is a little silver canister under the dash, to the right of the OBD II Sensor. This is a relay of sorts. I think it is called a relay flasher. I picked my new one up at a dealership for $15. It only took a Phillips, 7mm Socket, and pliers. Once the new one was put in my blinkers finally started to blink again. I still have the front ones, that sometimes will just go dark and not blink. I'm going to check and replace the sockets for the front blinkers and see if that fixes the rest of my issue. I hope this helps people fix these problems that plague 97's. I have heard that the Daytime Running Lights may also have something to do with these issues. I have found info on disabling your DRL's on just about any Chevy. I will post links to these sites when I can get back on my laptop.
Old 02-16-2012 | 01:34 PM
rv93's Avatar
thats the flasher they previously agreed was not the problem. and for future reference, you can get an OEM part at autozone for something like $3.
Old 11-10-2012 | 07:18 PM
Jeffs1997's Avatar
Your DRL module is bad
cmdeshon
Parts Wanted
12-16-2014 07:58 AM
siguy
11-27-2014 10:07 AM
squarehead
11-21-2014 08:02 PM
07-04-2005 05:00 PM
DubbyZ28Camaro
08-04-2002 12:53 PM
Quick Reply: 1997 Z28 front driver side turn signal doesn't blink
