1999 Z28 Camaro signal relay.
Old 04-06-2010 | 03:11 PM
brohemo's Avatar
When i turn the turn signal on, the dash indicator light lights up but its a solid light, no flashing. The exterior lights have the same problem they light but do not flash. I removed the flasher relay from under the right side of the steering column. Is this what needs to be replaced or could it be something else? Thanks everyone.
Old 04-06-2010 | 03:40 PM
Adam96Z's Avatar
Sometimes a burnt out bulb, bad ground, or bad socket will cause the same problem. Flasher relays are cheap so might be worth a try though. You can get one at any auto parts store.
Old 04-06-2010 | 09:53 PM
A burned out bulb or filament is the most common cause. Check bulbs.
NewsBot
12-28-2014 06:20 PM
Not Dave
12-11-2014 06:32 PM
pete53
12-09-2014 07:31 AM
Brandon Wittmer
12-03-2014 09:28 PM
07-04-2005 05:00 PM
Quick Reply: 1999 Z28 Camaro signal relay.
