2 hopefully simple questions
Re: 2 hopefully simple questions
The higher the pressure, the hotter the coolant can be before it boils.
The volt gauge seems to be reliable, but usually the feed to the gauge and ignition switched components is compromised by a slight voltage drop. That means that your gauge may read a little lower than a reading taken at the battery (especially in the heat).
Hurin
12-13-2014 07:38 PM
TheGreenZ28
Exhaust System
12-06-2014 10:23 PM
