87 IROC no headlights
Old 04-04-2020 | 07:16 PM
Eslund's Avatar
Picked up an 87 iroc barn find. Slowly getting it back into shape and found out that the headlights do not work. Marker lamps work interior lights work dash lights work blinkers work rear lights work but no headlights. Tested the yellow wire into the dimmer switch and it has voltage coming to it. Checked continuity through dimmer switch and it works as it should. Checked continuity from dimmer switch to headlights through green and brown wires and it’s good. What the hell am I missing?
Old 04-05-2020 | 01:29 PM
peterpar's Avatar
Re: 87 IROC no headlights
Have you checked for a ground at the headlights? I noticed sometimes when a car has sat for a long time, a film or corrosion in the connectors prevents a good connection.
Old 04-06-2020 | 09:55 PM
Eslund's Avatar
Found my issue. Had voltage at the yellow wire but it wasn’t 12v it was only 10 so I tore the cluster out and pulled the switch and had 12 at the red wire. Bypassed switch and everything works so my switch is bad. Thanks for responding!
jerryandy
08-20-2007 09:38 AM
LT1Squirrel
09-22-2004 09:06 PM
Camaro91RS
3rd Gen / L98 Engine Tech
09-03-2003 10:18 PM
97 SLP Company Car
05-08-2003 12:31 AM
stepuptata
10-24-2002 09:58 AM
Quick Reply: 87 IROC no headlights
