93 camaro z28 5.7 wiring issue
Old 03-20-2022 | 03:46 PM
93z28will's Avatar
Purchased this car and need some guidance. No idea where this wire should go.
Any help would be awesome. Pulled fuse box out and noticed this wire. No idea what it is supposed to connect to.
Car does not idle right now and stalls when you apply any throttle.
More exposed
More exposed
More exposed wires
Old 03-20-2022 | 07:41 PM
Re: 93 camaro z28 5.7 wiring issue
Definitely doesn’t look like anything “factory”. Looks like someone ran a white wire to the fuse box and really hacked an attempted splice. Best bet would be to try and find where the white wire comes from.
Old 03-20-2022 | 07:48 PM
93z28will's Avatar
Yea I haven't been able to find where it came from. Nothing I can find matches up with the wire. I do know I lost my fuel injection after messing with it.
Old 03-25-2022 | 04:11 PM
Does the fuel pump still prime when you turn the key to “run”?
Sorry about the delay. For some reason the system put your second post into the “approval” queue.
Old 03-25-2022 | 09:09 PM
93z28will's Avatar
Right now I went from running fine to no start. I bought the car and was just going over it all and seen the wire behind the fuse box. It was originally a red wire but looks burnt and replaced with the white wire. After I tried to chase the wire to see where it went I lost all fuel delivery.
jordankeck
04-20-2012 12:35 PM
nas-T-72z
07-20-2006 09:29 PM
Napoleon001
07-20-2006 10:24 AM
BlackRamair95ta
04-17-2006 09:17 PM
racinmyz28
04-19-2003 10:41 AM
Quick Reply: 93 camaro z28 5.7 wiring issue
