94 v6 camaro high idle
Old 03-29-2020 | 03:07 PM
codyleej's Avatar
Hello was fixing my head gasket and its my first time working on cars. And ive put every rhing back but the only problem I have now is super high idle. I cant figure out were its comeing from beause ive have check every vacuum line for leaks and every thing looks fine. I did a smoke test and it only came up near the feul rail. I was wandering if any one knew what the promblem could be. Thanks
Old 03-29-2020 | 04:22 PM
Re: 94 v6 camaro high idle
“New Member Intro...” isn’t the best place to get tech help. I'll move this to a forum where you are more likely to get a response.
Have you verified that something in the throttle cable/linkage isn’t holding the blade open?
Old 03-29-2020 | 04:43 PM
codyleej's Avatar
Thanks I didnt relized I posted it there. And no I havent check the throttle cables yet thanks
Old 03-29-2020 | 10:24 PM
And, are you sure you reconnected the idle air control (IAC) valve?
Old 03-30-2020 | 03:04 PM
codyleej's Avatar
yea I even bought a new one.
HappySalesman
05-15-2014 02:14 PM
Quick Reply: 94 v6 camaro high idle
