95 Z28 Passenger window connector
Old 07-26-2019 | 11:52 PM
  #16
peterpar's Avatar
Re: 95 Z28 Passenger window connector
I'm not sure I understand what you're trying to tell me. You have to hold the passenger window button in the down position on the drivers door switch before the passenger door switches will work?
Old 07-27-2019 | 12:12 AM
  #17
peterpar's Avatar
With the ignition switch in the run position, set your meter on DC Volts and check for voltage between terminal "A" of the passenger door switch connector and terminals "B", "C", "D" AND "E". You should have a 12V reading between "A" and each of the other terminals. No voltage between "A" and "B" or "A" and "E" terminals would be indication that the driver door passenger window switch has contacts that are burnt and not making contact until you activate the switch. If that is the case, the driver door switch is going to have to be replaced.
Old 07-27-2019 | 04:52 AM
  #18
Joseph Krollage's Avatar
The passenger door window switch will work but only for down unless i hold the drivers door passenger window switch down then it will let it go up. I will check that tomorrow I’m just glad i have a breakthrough finally
DontMixWithRice
06-05-2006 01:45 PM
BlazeV638
03-15-2006 02:22 PM
scottso
12-16-2005 04:03 PM
red blur
06-24-2004 02:20 PM
ninetythreez
10-05-2003 04:46 PM
Quick Reply: 95 Z28 Passenger window connector
