95 Z28 trouble code 23
Car has problems starting once car warms up coolant fans come on and check engine light comes on at the same time
Getting trouble code 23 in my 95 z28
Manifold air temp sensor signal too low (MAT)
what could this be? Where to start?
Like always any help is appreciated
Re: 95 Z28 trouble code 23
The description is much clearer on Shoebox's list, because it is specifically for the LT1.
http://shbox.com/1/Dtcs.htm
IAT (intake air temp) sensor is the one plugged into the side if the rubber intake elbow. High voltage, low temp indicated.
http://shbox.com/1/iat.jpg
Sounds like the harness connector may have fallen off. If it’s not that, use Shoebox’s test procedure:
4th Gen LT1 F-body Tech Articles
warwickbass
08-21-2004 09:57 PM
