97 3.8 heater core?
Old 01-09-2014 | 09:38 AM
rswalley's Avatar
97 3.8 heater core?
i have no heat at all.i know the cooling system needs flushed,there is a bunch of old barrsleak or something throughout the system.but it has been my experence that even if heater core is clogged you will still get a little heat.on this car there is absolutely no difference between outside air temp & heat temp.garage i bought it from replaced raditor dont know why they diddnt flush system then. is there something to use to get the cooling system clean that will work
Old 01-09-2014 | 10:18 AM
Re: 97 3.8 heater core?
Detach the heater hoses at the water pump, and force water through it both ways with a garden hose. Try to limit the pressure applied to the system, to prevent overpressuring the core.
Old 01-21-2014 | 02:30 AM
z281997's Avatar
Thermostat?
Sent from my SGH-M919 using Tapatalk
SergheiS
09-29-2015 08:56 PM
Fatdog2
09-16-2015 11:04 PM
Pwilson59
09-03-2015 08:47 PM
GusarskiSS
Exhaust System
09-02-2015 03:51 PM
ducttape1975
07-10-2015 06:29 PM
Quick Reply: 97 3.8 heater core?
