97 camaro rear wheel bearings question
Old 11-05-2004 | 04:29 PM
hockgow's Avatar
In the last few weeks I've noticed a low murmuring noise coming from the rear. It's more noticeble as low speeds, which i suspect is due to less road noise.
I have a feeling, my wheel bearings need to be replaced. I was planning on this weekend checking out the wheel bearings by raising the rear and checking for any slack when i move the wheels.
If the wheels do move, then i know my bearings are shot, correct? The question is do i just change in the wheel bearings by removing the wheels and yank out the bearings straight from the axle or do i have to remove rear plate and take the whole axle out first?
A second but probably dumb question, what is the difference between an axle bearing and inner wheel bearing? Are they the same? Based on the noise I am getting do i need to replace these as well?
Old 11-06-2004 | 05:48 PM
HBHRacing's Avatar
Re: 97 camaro rear wheel bearings question
run teh car on jacks so you can make sure that it's not a pinion or carier bearing in the rear itself. If it is a wheel bearing then the cover needs to come off, the diff pin and c clips need to be removed and then the axles need to be pulled out. Then you can remove teh seal and finaly the bearing.
Old 11-07-2004 | 11:18 PM
Jacobs454's Avatar
How long are these stock bearings supposed to last. I have 170K on my car!
Old 11-08-2004 | 07:24 AM
HBHRacing's Avatar
if you take care of the car most people will never have to replace them.. but it does happen
Patricklt1
04-24-2015 06:29 AM
CaRParts102
12-06-2014 08:45 AM
ChrisFrez
11-30-2014 08:41 AM
blac94Z
11-24-2014 07:12 PM
squarehead
11-21-2014 08:02 PM
Quick Reply: 97 camaro rear wheel bearings question
