Abs, tcs, trouble codes
My abs inop light is on all the time. My tcs button won't light up, tcs off doesn't light on dash. Performance Trans button won't light up but its working according to the scan9495 software. I can't get that to show any abs codes. I am getting codes 26,27,77. I did do an egr delete.
Just swapped out a95 Camaro column into my TA and now the turn signals don't work. Are the turn signal and hazard flasher the same or are there 2 of them?
Sent from my R800x using Tapatalk 2
Prominent Member
Re: Abs, tcs, trouble codes
Prominent Member
Good for you! By the way, there have been many enhancements and improvements since June. You should download the newest version. You can keep the old scan9495.exe file in another folder if you wish.
armedtrigger
02-24-2015 08:30 PM
squarehead
01-15-2015 07:02 PM
